Air In Water Supply Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-18-2009, 07:16 AM   #1
Air in water supply lines
I had a leak under the kitchen sink and had a plumber replace all the lines and shut off valves - hot, cold water, ice maker and dishwasher. He also replaces the lines with PVC. Everything was fine for about 5 days, but now everytime I turn on any faucet or the shower there is a small amount of air in the line. This occurs when no water has been run in the house for several hours. What could be causing this?
Mira626 is offline   Reply With Quote
Old 05-18-2009, 08:20 AM   #2
Rewards Points: 356
When you run the water for a few minutes then fill a glass is the water cloudy then turn clear in a few minutes? If so that would be an indication or air entrainment in the water supply coming in to the house. As the water sit undisturbed in your lines it can separate (like soda gives up CO2).
RegeSullivan is offline   Reply With Quote
Old 05-19-2009, 06:54 AM   #3
Rewards Points: 150
might check to see if you have another leaking faucet in the house either inside or out allowing air to enter the pipes when you turn the water on.
al's sewer is offline   Reply With Quote
Tags
air in water lines
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 05:18 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
Can water supply pipes be PVC?? i need general help... hallbum Plumbing 5 12-10-2005 01:22 AM
