Air In Water Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2009, 08:47 PM   #1
air in water lines
i get air out of me faucets whewn i turn them omn . Also it seems like my hot water runs out half way through a shower and does not last. How can i fix this?
tommart is offline   Reply With Quote
Old 01-06-2009, 09:48 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
AIR - If you're on a public water supply, they may have been working on the lines nearby. If so, just run the facuets until the air is gone.
If you're on a private well and pump, there may be a leak in a line on the suction (well) side of the pump that is allowing air into the line, or there may be a leak in the prssure tank bladder (which means replacement).
HOT WATER - If you have a standard electric water heater, you probably have a bad lower element. Test it by turning the power OFF, disconnecting the wires to the element, and then test the element screws with an ohm meter...no conductivity...replace element.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 10:59 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Water Mystery - Sump Pump Set Right? robertr4836 General DIY Discussions 4 02-13-2008 03:32 PM
air in water lines econdave Plumbing 5 08-24-2007 01:16 PM
