Old 07-23-2012, 09:46 AM   #1
Air vent size
I have a 4-way pvc tee with 2" openings all around. One will vent the shower, one the sink and one the toilet. The 4th opening will connect to the 3" roof vent. Is that 2" to 3" sufficient, or is it much better (as I suspect) to have a direct 3" opening into the roof vent pipe?
harmonyhill is offline   Reply With Quote
Old 07-23-2012, 10:28 AM   #2
Doing it myself
Alan's Avatar
Air vent size
2" is a sufficient vent for what you mentioned above. If you wanted you could replace the 3" roof jack with a 2" roof jack as long as nothing else is tied into the 3". If there is something else tied into the 3" then you'll obviously need to cut in a 3x2 fitting and connect there.
There's also nothing wrong with leaving the 3" vent and connecting to it with a reducing coupling if needed.
Journeyman Plumber
Alan is online now   Reply With Quote
Installing a gable vent..from *inside* the attic steveKane Building & Construction 8 12-09-2012 03:45 PM
New Roof marknok Roofing 4 08-06-2011 12:41 PM
Plumbing Vent Size CMHbob Plumbing 4 07-23-2011 08:32 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
Foundation crawl space vent size problem Constant Improvement Building & Construction 15 01-15-2009 06:07 PM
