Air Test Old Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2012, 07:30 PM   #1
Air test old plumbing
I am buying a foreclosure and the property condition report states that the plumbing does not hold pressure. I want to air test the plumbing myself to determine if there is actually a problem. The pipe is copper. I have extensive experience in the construction/remodeling industry and now work in the natural gas industry, so ability is not an issue. Finding gas leaks is part of my job. I am looking for suggestions on what pressure to test at? Where to test (I am thinking the laundry connections)? I am also thinking that the problem is likely a bad valve... Thoughts?
DouginATL is offline   Reply With Quote
Old 04-05-2012, 08:46 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 826
I'd test up 1.5 times working pressure. Treat it like testing gas-isolate fixtures as much as possible. Washer box sounds good- you can test hw lines or cw lines. I'd leave the test on for an hour too
Old 04-05-2012, 08:50 PM   #3
How would I find out the working pressure? I am also worried about overloading the valves. I have seen where people have recommended testing between 75-100PSI. Is that too much? Any idea what the plumbing code says? Am I overthinking it?
Old 04-05-2012, 09:00 PM   #4
Plumber
Rewards Points: 826
I would test between 60-100. Working pressure is ideally around 60. Check to see if you have a PRV at the building supply shut off. You may want to remove it for the test. Treat it like a gas valve- not sure if you should back test against it. I would test the hose first, then test the service line- process of elimination. Hopefully the leak is in the house and not buried outside.
Old 04-05-2012, 11:03 PM   #5
Rewards Points: 636
it will fail if there is a leaky faucet also
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Bathroom remodel, sink plumbing dschmid Plumbing 3 02-03-2011 08:32 PM
Basement Bathroom - plumbing thoughts (pics) rkerns Plumbing 1 01-12-2011 04:14 PM
Demo'd Half-Bath, Pics Attached, Any Plumbing? 99altrade Plumbing 12 12-23-2010 09:48 AM
Final drain test, tricks to finding the leak jdspace Plumbing 0 12-26-2009 10:52 PM
