Old 12-08-2012, 11:23 AM   #1
Air temperature affecting expansion tank air psi
I've got an expansion tank in my attic near the hot water heater and the air psi in the expansion tank can vary 5 or 6 psi depending on the air temperature in the attic. I live in Texas where it gets very hot, and freezes from time to time. I added air when the temperature was about 70* or so thinking that is a good median temp. Any other tips or ideas? Is that much of a difference a big deal? Should I wrap insulation around the tank? Thanks in advance.
Austin83 is offline   Reply With Quote
Old 12-08-2012, 11:39 AM   #2
shouldn't vary that much unless tank is flooded, i.e., no air in tank.. if not bladder type..shut off water and .drain water to below air tank level...open any fitting to air tank (drain valve?) to allow to fill with air..close valve and refill system this will provide proper cushion..if bladder type..equipped with air fill valve then check pressure with tire gauge without water pressure in system..should be same as normal water pressure..if can not be pressureized then bladder defective..replace tank
techpappy is offline   Reply With Quote
Old 12-08-2012, 12:08 PM   #3
The tank is new and it is working properly, but just like tire pressure the air pressure will vary depending on the outside temperature. The temperature in an attic can vary from 40 to 80* daily this time of year, and up to 130* in the summer
Old 12-08-2012, 12:42 PM   #4
A "Handy Husband"
rjniles's Avatar
Leave it alone, its working.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
TheEplumber (12-08-2012)
Old 12-08-2012, 01:07 PM   #5
call me E
TheEplumber's Avatar
Are you talking about a water heater expansion tank? You're over concerned. I bet your water pressure varies that much during the day. No way can you keep them calibrated that close.
Old 12-08-2012, 01:15 PM   #6
Yes, hot water expansion tank. Thanks for the reply. The water pressure is regulated by a reducing valve but it does vary by that much between normal water usage and the pressure will increase some while the hot water heater is heating water. Thanks again.
Expansion tank size problem Austin83 Plumbing 7 11-16-2012 08:58 AM
Expansion Tank Electric Hot Water dougp23 Plumbing 1 12-27-2011 08:27 AM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 10:29 AM
Installing an expansion tank Homerepairguy Plumbing 1 01-25-2011 09:10 AM
Sweating windows big daddy-o General Discussion 15 01-06-2008 03:41 PM
