Air Stop / Hammer Stop - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2008, 10:08 AM   #1
Rewards Points: 262
Whatever the technical term for it, those are the two I have learned for the vertical pipe that comes off a water line at an elbow to stop the water from "hammering" into the pipe when the flow is stopped. Anyhow, right now they come up behind the knee wall in my second floor, about 18" high. Of course, the only place I can put a door to access that area behind the wall is right where they are. Can I cut the vertical pipe off, run the main line over another 16", and then go vertical with it? Or will this lose effectiveness?
moneymgmt is offline   Reply With Quote
Old 02-13-2008, 10:42 AM   #2
I don't think it will interfere with the effectiveness. What the hammer eliminator is doing is holding air to provide a "cushion" to prevent hammering.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 07:26 PM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 07:00 PM
What is the best type of door stop for front entry door? KUIPORNG Carpentry 5 06-29-2007 04:23 PM
Water Hammer ffgus Plumbing 3 12-31-2006 10:19 AM
