Air In Pipes After Water Softener Regeneration - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-18-2010, 07:12 PM   #1
Just call me Andrew
Rewards Points: 1,020
Air in pipes after water softener regeneration
Some friends of mine have an older Culligan Mark 50 water softener (from 1987). Usually in the morning, after the softener regenerates, well I think that's what it's doing, there is air in the pipes and while I don't think it's causing a problem, the sputter in the morning is irritating.
Any ideas? Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 10-20-2010, 08:22 AM   #2
Just call me Andrew
Any ideas on this? Thanks.
Andrew
Old 10-20-2010, 09:12 AM   #3
Rewards Points: 150
I am pretty sure my system does that too, mine is also older. I just live with it.
240sx4u is offline   Reply With Quote
Old 10-20-2010, 09:23 AM   #4
Just call me Andrew
It didn't always do it...so that leaves me to believe something is wrong...
Andrew
Old 10-20-2010, 10:16 AM   #5
No troubleshooting guide in the manufacturer's literature/operating instructions? Maybe call their technical help line.
Ishmael is offline   Reply With Quote
Old 10-20-2010, 12:40 PM   #6
Check the fittings on the brine line that runs between between the brine tank and at the softener control valve (if a two tank system) (if a cabinet model look inside the cabinet to find the brine line between the well fitting and the control valve). A loose fitting can allow air to be drawn in during the brining cycle. It can also cause incomplete regeneration.
Bob999 is offline   Reply With Quote
The Following User Says Thank You to Bob999 For This Useful Post:
secutanudu (10-20-2010)
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 09:24 PM
GE 40,000 Grain Water Softener soxcycling Plumbing 7 04-08-2010 05:20 AM
Pex vs. copper, running a new line to water softener. ams4life Plumbing 9 03-05-2010 04:47 PM
Is this a viable solution for a water softener? imola ghost Plumbing 1 12-23-2008 10:51 PM
