Air In Pipes? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2013, 08:42 PM   #1
Rewards Points: 14
Air in pipes?
Hi. When I came home from work today and turned on various faucets in my home, I noticed that there was air in the water lines. It was as if the main water supply to the house had been turned off during the day. However, we we werent home all day and I cant think of a reason why this would have happened. I have had a contractor doing some work here, but he said he was not here today.
So I am curious if there are other reasons why the pipes may have air in them? Could someone have been doing work on the water supply lines outside of my home? There was a significant temperature drop from yesterday (60 degrees) to today (below freezing)...maybe that is why? But of course we didn't notice anything this morning.
Thanks!
Dave43026 is offline   Reply With Quote
Old 01-14-2013, 08:57 PM   #2
Rewards Points: 13,300
#1 Go back and add your location to your profile please.
Did just some air come out then the water started flowing? Or is there still just air?
Old 01-14-2013, 09:14 PM   #3
Rewards Points: 14
There is no longer air in the lines, and water comes out of every faucet like normal. I guess I was just curious as to what may have caused the situation.
Profile location should be updated.
Old 01-14-2013, 09:25 PM   #4
Thanks.
Just be glad it's working again.
Old 01-14-2013, 09:45 PM   #5
joed's Avatar
Rewards Points: 12,024
Town could have had a water main shut off for repair. This time of year in cold areas frost tends to cause breaks more than warmer weather.
The Following User Says Thank You to joed For This Useful Post:
Javiles (01-14-2013)
tree roots and orangeburg pipes xerxes2001 Plumbing 3 04-07-2012 09:26 PM
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 12:20 PM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 09:10 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 09:15 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 10:03 PM
