Air In Newly Replaced Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2011, 04:29 PM   #1
Air in newly replaced pump
I recently moved into a house that had been unoccupied for four years. After seeing that the existing shallow well pump was cracked, I installed a new one and started in on installing PEX throughout the house. Right now I'm having the issue of air being trapped in the holding tank and letting the water flow back down the lines. I have had the pump running with the nearest faucet open to try to bleed the line for the past forty minutes. The water that comes out is filled with tiny bubbles. Is there something else I should do to try to get the air out, or should I just continue as I am?
qcarswell is offline   Reply With Quote
Old 11-28-2011, 06:36 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,648
Ayuh,... It sounds like it's drawin' in Air, on the suction side...
replaced flooded convertible jet pump, pressure will not go over 30 lb. dcreech Plumbing 4 09-18-2011 10:14 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 07:55 AM
Reconnect a Replaced 3/4 hp motor on Polaris pool booster pump - gekunkel Electrical 1 10-08-2010 04:12 PM
Rain Collection System Using Collection Tanks in Multiple Locations Gheuett Landscaping & Lawn Care 10 09-15-2010 08:30 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
