Old 02-21-2012, 01:31 PM   #1
air lock in drain?
We put in a new toilet. Worked fine until we ran water in tub. Now nothing drains right? How do we get air lock out of lines?
tammy s is offline   Reply With Quote
Old 02-21-2012, 01:53 PM   #2
air lock in drain?
if it is air locked you need need to remove a trap but we would first like to here what was all done drain and vent wise so you can get some suggestions from panel for a permanent fix
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
tammy s (02-21-2012)
Old 02-21-2012, 02:09 PM   #3
air lock in drain?
We only put in a new toilet with new wax seal. Flushed fine for whole day until evening when I ran water in tub. The water backed up in tub, sink and toilet. Thought it may have gotten clogged due to different toilet water pressure?(new toilet is an efficiency one that uses 1.28 gallon of water) Plunged, no help. Then drano, no help. Have been reading about "air or vent locks". Before we used tub, my husband did turn off water to replace a fitting on line going into back of toilet. While it was "drying", is when I turned water on in tub and it started backing up.
Old 02-21-2012, 02:29 PM   #4
air lock in drain?
ok i would suspect something fell down pipe when toilet was removed you might need to call someone to snake or run camera call multiple companys price can very majorly due to size and frandchise costs
Old 02-21-2012, 02:32 PM   #5
air lock in drain?
i have had a child do that before on a job and also had someone cover hole to block smell with rag then forget to pull rag before setting new toilet
Old 02-21-2012, 02:48 PM   #6
call me E
TheEplumber's Avatar
air lock in drain?
I got to agree with some kind of blockage. It's prolly worked it's way downstream from where the tub ties in.
What your husband did to the water supply should have no bearing.
I once had a cleaning rag get flushed down a commercial toilet- it went 40' before it hung up and caused a flood in the mech. rm. floor drain. Better ask everyone in the house to come clean if they flushed something that shouldn't have been flushed
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 02-21-2012, 04:48 PM   #7
air lock in drain?
thanks for your help. Noone lives with us except my husband and me. We really don't think anything fell in. But I guess we will keep trying.
Old 02-21-2012, 10:27 PM   #8
air lock in drain?
I have to agree with others ...sounds like a clog..not air lock....water is backing up in tub and sink....most air locks will release at some point or when you flush commode it will blow trap seal on tub or sink for air????
Old 02-22-2012, 07:50 AM   #9
air lock in drain?
Thanks. It does eventually go down after a longggggggggggg time. We are going to get a snake today.
The Following User Says Thank You to tammy s For This Useful Post:
ben's plumbing (02-22-2012)
Attaching basement bathtub drain to main drain herbie08 Plumbing 0 04-10-2011 05:13 PM
Sink drain leaking, question bergerdude Plumbing 3 03-27-2011 01:43 PM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 01:49 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
