Air In Lines? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-03-2012, 09:43 PM   #1
Air in lines?
recently when showering or opening hot water supply at fixtures, im having air shoot out of showerhead or faucet for like 5 - 10 seconds. Sometimes its quite strong. How is it getting in the water lines? Ive repiped the entire house with CPVC 10 years ago.
cariboulou is offline   Reply With Quote
Old 07-03-2012, 09:47 PM   #2
Rewards Points: 14,306
Well or public water?
Had any plumbing work done latly?
Do you have an air tank in the system?
Old 07-03-2012, 10:02 PM   #3
City water supply. Havnt had any work done recently. No air tank, cold flows through a water softener, then into HWH...no expansion tank.
Old 07-03-2012, 10:10 PM   #4
Try opening up the refief valve on the water heater untill water goes out, then start opening up every valve starting with the closest one to the incoming water line, outside taps, flush every toilet, sink, tub and shower.
Could be as simple as one of the lines in the street has been worked on causing it.
underground electical lines BlueBSH Electrical 11 02-10-2012 03:52 AM
Connect Air Cond Drain to House Waste lines AdamOJ Plumbing 19 11-23-2011 06:47 AM
Low point in water supply lines dave11 Plumbing 3 02-01-2011 07:13 PM
slow hot water lines sobro Plumbing 3 11-05-2010 10:44 AM
Why move/replace heat pump refrigerant lines? EdLank HVAC 1 05-09-2010 05:02 AM
