Old 09-15-2012, 05:08 PM   #1
t60
Air Gap for 1.125in hole?
Is there anything I can do in this situation? I have a 1.125in deck hole in my granite countertop, which fits RO faucets fine, but not air gaps. The existing 1.125 hole is less than an inch away from the edge, so there is a very high possibility the granite will crack if anyone attempts to make it larger; the possibility is so high, that every granite shop I've called in town will not guarantee they won't crack it by making it bigger.
I've called a plumber to take a look at my high drain loop, and he said it looks fine, and didn't change it at all. Problem is, every month or so the drain loop gets backed up and my dishwasher turns my kitchen into a swimming pool.
I've tried looking for 1.125in air gaps, but I don't believe they exist. Is there anything else I can do, or am I stuck with a faulty drain loop, or risk cracking the granite?
I don't mind having an "ugly" air gap on the counter, I just want my dishwasher to work
t60 is offline   Reply With Quote
Old 09-15-2012, 05:41 PM   #2
An air gap isn't going to stop water from backing up. It'll just leak out in a different place. You need to find out why it's backing up in the first place.
Old 09-15-2012, 07:25 PM   #3
By any chance, did you secure that drain loop so that it stays in place?
I used a stainless steel clip that is screwed on to the side of the cabinet (underneath my sink) to secure the flex line.
allthumbsdiy is offline   Reply With Quote
Old 09-15-2012, 08:53 PM   #4
call me E
TheEplumber's Avatar
How is your hose connected to the sink plumbing and is the DW's factory hose used the whole distance? If not, is the extra hose the proper size?
Old 09-15-2012, 10:52 PM   #5
Master Plumber
Javiles's Avatar
Get Rid of It. those things are nothing but trouble.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 09-16-2012, 02:23 AM   #6
Doing it myself
Alan's Avatar
I agree with this. Something is causing the drain to back up, and an air gap won't stop it.
Figure out what the problem is and fix it.
Journeyman Plumber
Repair Small Hole in Vinyl Siding Silkcityflorida General Discussion 12 04-08-2013 04:34 PM
Cutting Hole for Bathroom exhaust jburchill Kitchen & Bath Remodeling 14 04-16-2012 12:55 PM
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 07:55 PM
Need to enlarge hole in wood top plate: or use flex with minimum OD. mysterylectric Electrical 3 08-09-2011 03:52 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 10:26 AM
