-   -   Air Gap for 1.125in hole? (http://www.diychatroom.com/f7/air-gap-1-125in-hole-156904/)
t60 09-15-2012 05:08 PM
Is there anything I can do in this situation? I have a 1.125in deck hole in my granite countertop, which fits RO faucets fine, but not air gaps. The existing 1.125 hole is less than an inch away from the edge, so there is a very high possibility the granite will crack if anyone attempts to make it larger; the possibility is so high, that every granite shop I've called in town will not guarantee they won't crack it by making it bigger.
I've called a plumber to take a look at my high drain loop, and he said it looks fine, and didn't change it at all. Problem is, every month or so the drain loop gets backed up and my dishwasher turns my kitchen into a swimming pool.
I've tried looking for 1.125in air gaps, but I don't believe they exist. Is there anything else I can do, or am I stuck with a faulty drain loop, or risk cracking the granite?
I don't mind having an "ugly" air gap on the counter, I just want my dishwasher to work :thumbsup:
md2lgyk 09-15-2012 05:41 PM
An air gap isn't going to stop water from backing up. It'll just leak out in a different place. You need to find out why it's backing up in the first place.
allthumbsdiy 09-15-2012 07:25 PM
By any chance, did you secure that drain loop so that it stays in place?
I used a stainless steel clip that is screwed on to the side of the cabinet (underneath my sink) to secure the flex line.
TheEplumber 09-15-2012 08:53 PM
How is your hose connected to the sink plumbing and is the DW's factory hose used the whole distance? If not, is the extra hose the proper size?
Javiles 09-15-2012 10:52 PM
Get Rid of It. those things are nothing but trouble.:mad:
Alan 09-16-2012 02:23 AM
I agree with this. Something is causing the drain to back up, and an air gap won't stop it.
Figure out what the problem is and fix it.
