Old 07-28-2010, 02:36 PM   #1
Air conditioner is leaking from top of furnace
I have an old air conditioner and furnace... Just the other day I noticed a bunch of water on the floor and it is leaking from between the duct work and the top of the furnace. I removed the drain hose and flushed it out with bleach, seems to have no obstructions so I hooked it back up to the 1/2" copper fitting that runs to a drain. It does go uphill at the end but it has never given me this problem in the last 3 years so I doubt that is it. What is the next step? Could it need a new evaporator coil? Could it just be plugged up somewhere else? Thanks, this is driving me nuts and I am almost ready to get a a plumber in to look at it.
lt1tyrell is offline   Reply With Quote
Old 07-28-2010, 04:15 PM   #2
Remove the front cover panel to expose the coils and pan. The drain is probably backing up due to a blockage.
handy man88 is offline   Reply With Quote
Old 07-28-2010, 06:08 PM   #3
Ok thanks I will see what I can do!
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Heat pump vs. Furnace and Air Conditioner heating&cooling HVAC 11 06-16-2010 07:07 PM
AC leaking condensation leaking into furnace jrf0022 HVAC 1 06-05-2010 08:52 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
