Old 08-05-2012, 05:41 PM   #1
Unhappy
Air conditioner condensate drain connections
Recently, the caulk/putty/whatever around this PVC piece (name: unknown) attached to my furnace developed two gaping holes on the underside (not shown), causing all condensed water to drain onto my basement floor instead of going through the PVC pipe to the condensate pump. I've plugged up the two gaps with silicone sealant (good for aquariums) and will test it when we return from vacation. Since I have no idea what this connection looks like inside, is it possible the water will now just go elsewhere and come out onto the floor in a new spot, or do you think I solved the problem? The unit is a Trane, 15+ years old.
agoldin is offline   Reply With Quote
Old 08-05-2012, 05:51 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Can not really tell from your over sized pictures. Really, can you resize them down to a smaller size.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 08-05-2012, 07:30 PM   #3
(it seemed like they were getting resized but they weren't really...)
Air conditioner condensate drain connections-img_1420a.jpg   Air conditioner condensate drain connections-img_1424a.jpg   Air conditioner condensate drain connections-img_1426a.jpg
Old 08-14-2012, 06:12 AM   #4
thanks to the advice I got on THIS page: http://www.paulstravelpictures.com/H...ide/index.html
I was able to find out that it was just some gunk clogging the pipe. Once I sucked it out with a wet/dry vac, water started flowing again and I turned our A/C back on. Voila!
Tags
a/c, condensate, drain, furnace, pvc
Tying into 50's style clay drain tile perimiter system/exposed Pit / Wall membrane alecmcmahon Plumbing 6 12-29-2010 08:23 AM
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 11:40 PM
is it ok to drain condensate to a below slab interior perimeter drain? steveel HVAC 2 12-03-2010 06:20 PM
Condensate Drain Pan Leak tbfreeland HVAC 0 09-01-2010 11:34 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
