Air Conditioner Condensate Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-27-2009, 02:45 PM   #1
I had a company come out and install an air conditioner approx 5 years ago. The other day, my floor was ALL wet. I noticed that the air conditioner's condensate drain, drains into a hole in my floating slab that then would go to my sump pump to pump out the water. When looking inside the hole, rust remnants were clogging up the hole so it wouldn't drain properly.
The company told me that it wasn't their problem that it leaked, and that skum, buildup and due to the water table, that they weren't at fault. It wasn't my sump pump since at the time it was dry.
Let me know what you think, thanks in advance,
Chase
djchase88 is offline   Reply With Quote
Old 08-28-2009, 01:18 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
The old drain pipe in the slab is probably cast iron or even worse, galvanized, which is notorious for scaling up with rust and corrosion inside until eventually clogging completely.
See if you can rod or snake out the rust.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-28-2009, 06:28 AM   #3
biggles's Avatar
if that is galvinzed buried in the slab it must be rusting away inside with cold condensate running thru it.might consider snaking it out all the way into the sump outlet then take a lenght of clear plastic hose and feed it the lenght of the drain out.then try to radiator clamp it to the exsisting PVC going into the floor.
Old 08-28-2009, 07:14 AM   #4
Chicago, IL
Michael Thomas's Avatar
Simplest solution may end up being a condensate pump.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 08-28-2009, 09:43 AM   #5
There is no pipe, it just drips into the hole
Old 08-28-2009, 11:36 AM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
Are you telling us that the condensate drains into a hole that is not piped in any way to the place where it ultimately gets pumped out by your sump pump? If so, I can see why the installer said it's not his problem. I wouldn't take responsibility for a drainage system like that either. Unless he was the guy who recommended a drain system like this, in which case I would never use him again. It looks like you have plenty of vertical space, so I'd explore running a dedicated PVC drain from the unit to the sump pit. You need to keep a free air space between the exit of the unit drain and the inlet to the drain pipe, so that any draft inside the unit doesn't pull fumes/odors back through the trap and blow them through the ducting. Air handlers are notorious for growing slime that can clog drains. It may have clogged whatever route the water was taking to get to the pit.
Old 08-28-2009, 01:29 PM   #7
Thanks for all your responses
The contract said when he installed the air conditioner that a pump might be needed. He never gave us the option nor did he tell us that the hole was an issue. We wouldn't have cared how expensive the pump was since it was the correct thing to install. So the rust that is in the hole came from the Air Conditioner that he installed.
Old 08-28-2009, 03:17 PM   #8
In addition to re-routing the drain, I'd be pulling the side panel off of the unit and inspecting the drain pan and coil supports. Could be a poor galvanizing job and these parts are now corroding away.
Old 08-28-2009, 07:32 PM   #9
biggles's Avatar
so with no pipe in the floor it just makes its way to the sump!snake it and pull a clear plastic lenght of tube and connect it and your good to go...pumping it out it still has to make the sump
Condensate Overflow Drain Pan sspatriots HVAC 10 03-30-2009 02:19 PM
Condensor drain Captflx HVAC 6 08-17-2008 11:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
condensate drain on ac Thirdeye HVAC 2 06-12-2007 09:28 PM
