Old 02-24-2009, 08:08 PM   #1
Air Chambers
do you always install them or just when code requires?
I know this used to be more common but I see more and more plumbers not using them at.
So do you or dont you install air chambers with all you plumbing fixtures?
II Weeks is offline   Reply With Quote
Old 02-24-2009, 08:26 PM   #2
Air Chambers
they make mechanical air chamers now that you can use per bathroom group. they are sioux chief brand and are pre made and ready to solder or thread into a fitting but i know stl code calls for two per bathroom group and are generally located on the shower valve.
plumbbum0203 is offline   Reply With Quote
