Air Chamber Needed When Switching To PEX? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-23-2012, 09:16 PM   #1
Rewards Points: 37
Air chamber needed when switching to PEX?
I'm working on a bathroom remodel and have had to reloacate a vanity drain. When I opened up the walls, I found I will have to relocate the copper water lines for the vanity and tub/shower. There are all kinds of fittings to make the complicated bends that the builder made to get the copper through the wall and around the corner to the tub and shower. The copper comes up through the bottom of the wall and T's off to the vanity and then T's off to the shower/tub. The lines continue up to air chambers. If I cut off the copper near the floor and transition to PEX to more cleanly navigate my walls, do I need to go back with an air chamber and if so, what would the best way to accomplish this be?
interplexr is offline   Reply With Quote
Old 11-23-2012, 09:26 PM   #2
Rewards Points: 13,712
Better to do it now instead of after it's all done and you find out you need them.
A tee, short piece of Pex and a Pex plug will do it.
Tags
air chamber , copper , pex
Replacement Combustion chamber kit OK? safety1st HVAC 13 02-28-2011 09:14 PM
Need advice on quantity of primer and paint needed laurat Painting 8 01-01-2011 10:53 AM
Vaillant advice needed jdg88 HVAC 6 12-14-2010 05:11 PM
Combustable air, how much is needed? Lee Roy HVAC 9 10-27-2010 10:17 PM
no ductwork needed to install a wall fan ? amakarevic Plumbing 2 01-22-2010 05:23 PM
