Old 12-03-2006, 08:16 PM   #1
Air bubbles in toilet
Hello, thanks for your help in advance. Every once in a while, air bubbles come up through my toilet. They're quite loud, I hear them while in other rooms, and they make the water splash a bit. We're on a city sewer system, don't have a problem with clogs or anything.
I was just wondering 1, if there's anything that can be done about this, and 2, is this a sign of something serious? Anything I should be concerned about?
Thanks again.
thisperson is offline   Reply With Quote
Old 12-03-2006, 08:49 PM   #2
World famous jerk.
Until now.
You may have a clogged vent, and the system is aspirating through your toilet.
mdshunk is offline   Reply With Quote
Old 12-04-2006, 07:56 AM   #3
Ok, so how do I fix that? Is this a serious problem, ie could lead to bad things happening?
Old 12-04-2006, 05:31 PM   #4
If it is your vent, you need to go onto the roof (if it is safe to do so) and check for a blockage. This time of year you may find birdsnests, spiderwebs holding up leaves or even webs that have condensate on them and have frozen. Remove anything you can by hand and then flush with a garden hose.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-04-2006, 06:44 PM   #5
Journeyman Plumber
Ron The Plumber's Avatar
If you hear this only when water is run in the other fixtures, then the mainline is clogged up and will need cleaned out.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 04:43 PM
moving basement toilet cibula11 Plumbing 10 10-20-2007 02:22 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 05:32 PM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 11:09 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 09:34 AM
