Old 11-05-2009, 12:22 AM   #1
Default Air belch from water jet
I have a 35 year old toilet that has developed a problem in the water jet that pushes the waste into and over the U trap. Every flush, there is a large bubble of air that 'burps' before water starts flowing with any force from the low nozzle that pushes stuff toward the back of the toilet. this tends to bubble solids up and makes for a very weak flush. We sometimes have to flush twice or three times to get waste and paper to drain out of toilet bowl. Where does the air enter? How do I fix it? i shall try sore sort of acid wash to disolve calcium, but i don't think that will cure belch.
dusty_trails is offline   Reply With Quote
Old 11-05-2009, 08:38 AM   #2
This sounds like a clogged vent to me. Your toilet is starving for air to allow the flush to flow out. Think of a straw in a glass of water, if you hold your finger on top of a filled straw the water wont flow out. A stopped up vent does the same so the toilet can only drain with what small amount of air can get through the vent or in some cases will suck water out of the closest "p" trap in a sink or tub and breathe through that which causes a gurgling sound to come from the sink.
Vents are generally cleaned out by locating where they emerge through your roof and by augering down to free the clog or sometimes by using high pressure water from a garden hose.
faucetman886 is offline   Reply With Quote
Old 11-05-2009, 11:22 PM   #3
Does the vent enter the pipe directly? I don't think the bathroom itself lacks for ventillation. I can open the bathroom directly to the outside. It was designed to be accessable from the pool.
thanx for any education you can impart.
Old 11-05-2009, 11:39 PM   #4
a vent is part of the plumbing installation and would be a verticle pipe in the wall extending up from the main drain line and out through the roof. you might be better served to call a plumber for help.
Tags
toilet, toilet jet
More On This Topic
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
We've all heard the frantic request from the bathroom to bring the toilet plunger before the toilet runs over. All of us will cope with a toilet malfunction at one time or another. Some repairs are best left to the experts, but many fixes are simple once... Read More »
Using a Plunger on a Toilet
Using a Plunger on a Toilet by Expert Village
Okay, here we are with a clogged toilet. We're going to take, and we're going to try to plunge it. But the one trick I have to tell you about plunging a toilet is we take the plunger, we get all the air out of it we can first, we push it down all the way... Read More »
Few things are more annoying than washing your hands and discovering that the water level won't go down. However, if you take a few preventative measures, you'll reduce your odds of having to call the plumber. Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 12:33 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 08:59 AM
Gas Hot Water Heater Tank and Pressure Relief Valve skadoo323 Plumbing 0 01-12-2009 10:52 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 01:41 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
