Air Behind Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2013, 02:38 PM   #1
n2omichael's Avatar
Rewards Points: 115
Air behind Water
I've heard this expression used numerous times, and have been told it refers to proper venting through the stack, but, haven't actually had ANYONE who could actually explain what it meant?
All input welcomed!
Michael
n2omichael is offline   Reply With Quote
Old 09-09-2013, 07:15 PM   #2
Rewards Points: 226
Basically, if your DWV system is not vented properly with air behind sewage/water, traps will be sucked out and sewer gas will enter the house. It has to get air behind the water some way for everything to drain properly. The library will have many books on this subject as well, depending on how deep an explanation you want. This quick link might explain it a little better. Thanks.
understanding plumbing vents
jmon is offline   Reply With Quote
Old 09-09-2013, 10:01 PM   #3
Rewards Points: 582
want to see it ....take a straw put it into a glass of liquid put your finger over straw and lift it out of the liquid ..then take your finger off the straw...wa la ....ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
jmon (09-09-2013)
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
