Air Admittance Valves Vs. Open Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2012, 04:11 PM   #16
Originally Posted by JackOfAllTrades View Post
What about bathroom exhaust fan venting? How did you bypass that?
excellent observation -- I have DC (super quiet / energy efficient) wall exhaust fans, and they currently exhaust into the attic -- I really need to run these to an outside wall vent -- need to find one I like for metal building walls that has a good insect screen on it.
danster44 is offline   Reply With Quote
Old 08-13-2012, 05:46 PM   #17
Venting into the attic is not a good idea because you are introducing humid/moist air into attic space. Ideally you want that air to exit through the roof or wall to the outside.
Like you, I don't want to have vents protruding through the roof of my home because of energy reasons and pest issues. Currently the home I am in now has bathroom vents and I get earwigs, crickets, roaches and all types of creepy crawlers that crawl in from the roof, down the vent, and into my home. I tried putting screens on the interior covers but they can still fit through the sides.
My solution will most likely be a ERV setup which brings in outside air, filters it and then distributes it throughout the home. This can eliminate the bathroom vent issue. Other than that, one would have to find a really good screened stack that doesn't let in pests from the roof.
JackOfAllTrades is offline   Reply With Quote
Old 01-21-2013, 02:36 AM   #18
I also found this study article online regarding AAV vs. conventional venting systems:
http://www.google.com/url?sa=t&rct=j...,d.b2I&cad=rja
In the end the engineers determined that AAV's were better and cost less than the conventional venting systems.
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 08:14 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
