Air Admittance Valve In Basement Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-26-2012, 05:20 PM   #1
Air Admittance Valve in Basement Bathroom
New to the forum and appreciate any help.
I am installing a full bath in my basement. As seen in pic I have a 4" cast iron vertical waste stack that goes to outside of house and also horizonal under slab along basement wall. I want bathroom to start a couple feet from stack and in this order from stack; Toilet, Sink and Shower. Where in this configuration do I put the Air Admittance Valve? Thanks so much for any advice.
John Callahan is offline   Reply With Quote
Old 05-26-2012, 05:36 PM   #2
Rewards Points: 636
how far away is shower trap from sink.
also what is on the horizontal and vertical stack
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-26-2012, 08:02 PM   #3
The cast iron stack is connected to a full bath on the next floor. The horizontal run from the stack under the slab in the basement is connected to a washer drain and floor drain only. The stack vents to a 3" pipe through the roof. Vent is hard to access and also I dont think it can handle the new full bath in basement.
Thanks!
Old 05-26-2012, 08:09 PM   #4
Rewards Points: 636
how far from sink is shower going to be?
Old 05-26-2012, 08:23 PM   #5
Toilet, sink and shower will be in line (next to each other) at just a little more than minimum code requirements.
Old 05-26-2012, 08:29 PM   #6
Rewards Points: 636
depends on code if you are worried about it. i would put aav under sink and let it be a wet vent for shower and the toilet is fine
Old 05-26-2012, 08:36 PM   #7
Jay,
I am curious why the aav would be at middle fixture as opposed to, say at one end of the branch? I don't do much plumbing so I just dont exactly understand why the sink? Is it because the trap for the sink is the highest trap in the branch?
Thanks for your help!
Old 05-26-2012, 09:09 PM   #8
Rewards Points: 636
it would be like running the vent straight up and arming over to catch a shower then continuing up to catch sink with a t then vent going up through roof . also sink is highest fixture . you could put one for shower and then another for sink. toilet is self siphoning so it well drain through vent stack
Old 05-26-2012, 09:19 PM   #9
Jay,
Sincere thanks for your expertise.
Tags
aav , basement bathroom
basement bathroom breiding200 Plumbing 4 03-22-2011 11:40 PM
basement bathroom breiding200 Plumbing 2 03-15-2011 04:05 PM
Basement Bathroom Circuit PJ33P Electrical 1 02-12-2011 08:13 PM
Basement Bathroom Insulatation/VB? mfleming Building & Construction 1 05-06-2009 05:27 PM
Basement Reno - Laundry, Bathroom mostr Building & Construction 2 03-02-2009 10:50 PM
