Air Admittance Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-02-2011, 07:27 PM   #1
Air admittance valve?
Hello:
Does anyone know if I can use an air admittance valve on a washing machine drain that has no air vent?
Rlly001 is offline   Reply With Quote
Old 01-02-2011, 07:56 PM   #2
HVAC / Plumbing
Are you asking if it's code ?? Don't know about your area. Ok in my area as long as there not concealed in a wall
kenmac is offline   Reply With Quote
Old 01-03-2011, 07:22 AM   #3
Rewards Points: 150
Same here in all but 1 County...
Docwhitley is offline   Reply With Quote
Old 01-03-2011, 11:22 PM   #4
WaldenL's Avatar
Rewards Points: 268
Code depends on where you are, but I can tell you it will work. Mine has been that way for about 2 years, no complaints, ex-large capacity washer (but front load) and many loads on some days.
WaldenL is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Air Admittance Valve WFO Plumbing 4 03-23-2009 08:56 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
woud an air admittance valve help here? cephalopodian Plumbing 5 05-22-2008 10:04 AM
