Old 01-01-2008, 06:12 PM   #1
aging symmons temptrol shower valve
My Symmons shower valve lets water thru the bath outlet but not the shower head. It will let a trickle thru but as you move the diverter to the left for more shower head pressure, theres a thump and then no water passes. I've placed a new TA10 cartridge but no improvement. Do I need a whole new valve or can the diverter be repaired or am I way off base?
v240969 is offline   Reply With Quote
Old 01-01-2008, 06:24 PM   #2
hi you should be able to just replace the diverter. this break down should help
http://www.symmons.com/service/a8.cfm
ranman469 is offline   Reply With Quote
ball valve leaking bwall Plumbing 10 12-31-2012 08:25 PM
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
Unable to remove Shower valve abacuslearns Plumbing 8 10-27-2007 11:10 AM
Pressure Balancing Valve Installation kpstanton Plumbing 2 03-01-2007 11:30 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
