After Toilet Fix - No Hot Water To Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-09-2011, 02:51 PM   #1
after toilet fix - no hot water to bathroom
When tightening pipe to toilet the entire fixture came out from wall and there was massive water burst. after turning off valves in basement. and replacing fixture, toilet works perfectly but cannot get hot water to return to sink and shower in affected bathrm. also cold water only works in shower when sink faucet is turn on in same bathroom. I never touched sink plumbing and all valves are returned to ON position in basement and under sink. all other water throughout house works properly. Please help me.
ladyfixit is offline   Reply With Quote
Old 10-09-2011, 04:11 PM   #2
Mark Potter's Avatar
Rewards Points: 150
Ok before we start with going back to the toilet area you made shore all your valves that you turned off in basement are back on? I know you stated that you check but if something blows out with water all over the place we don't think about what we shut off in the panic stage of shutting water off.
So what exactly blew off? The shut off valve to toilet or the hole pipe beyond the wall?
H|P Capital
Mark Potter is online now   Reply With Quote
Water dripping from second floor toilet area noquacks Plumbing 8 07-10-2011 03:16 PM
water line to toilet drips after toilet seal replacement J-lou Plumbing 1 10-20-2010 07:28 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
toilet water nikotromus11 Plumbing 7 03-18-2008 08:47 PM
