After A Shower, Tub Faucet Leaks From Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2012, 12:22 PM   #1
After a shower, tub faucet leaks from wall
After taking a shower, my tub faucet leaks at the base of the wall. how can this be fixed
Not so much is offline   Reply With Quote
Old 08-12-2012, 01:14 PM   #2
Rewards Points: 582
i give up ...how.... picture might help
Old 08-12-2012, 01:29 PM   #3
do you mean that water drips from the opening of the tub spout?
does the spout have a knob you lift to make the shower come on?
if that is the case the water is what is in the line going up to the shower head and will eventually drain out. i usually push the diverter on the spout down after a shower and it drains out right away. the water that is still in the shower head may drip out after a shower also. if it isn't dripping all the time it doesn't sound like a problem.
Replacing shower faucet Sketch Kitchen & Bath Remodeling 5 08-12-2012 12:53 PM
Stud wall return on a preformed shower base latelifebiker General DIY Discussions 5 11-30-2011 03:56 PM
shower wall stability rtoni Building & Construction 7 01-27-2011 04:11 PM
How to know if shower wall plumbing is leaking? dolvio Plumbing 3 10-27-2008 06:11 PM
shower faucet Cartridge leaks Dragontat2k Plumbing 2 05-21-2008 03:16 PM
