After Concrete - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-08-2009, 03:33 PM   #1
Rewards Points: 12
after concrete
I am installing new drains and will be pouring concrete over all when finished.
What is the best way to do the toilet flange, shower, floor drain and sink drain.
I would like to keep everything flush so I can screed the concrete over everything. Then install after.
Can I put some kind of cap over things and chip out after?
I will be putting tile down over the concrete.
rrekih is offline   Reply With Quote
Old 06-09-2009, 06:38 AM   #2
Not sure what you are looking for. Assuming PVC??? The toilet flange should be flush to 1/4 above the finished floor. Other drains usually stick up more, with enough material to fasten other components. You just have to screed around those things, then trowel finish.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
