Aerator Pump Size For Septic Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2011, 03:16 PM   #1
Rewards Points: 1,010
Aerator pump size for septic tank
The septic aerator pump kicked the bucket after 20 faithful years of service at my Mom's house. I'm looking to save her hundreds by buying and installing a replacement on my own, but I have some questions about the size.
The old pump was a 1/2 Hp, 10 cfm pump. Do you base the cfm on the size of the septic tank or on the amount of water usage in the house? At the time the house was built, 4 people lived there. My Mom lives alone now, so there's minimal water usage each month. Don't know the size of the tank, I'm still trying to find that out.
If I can step down to an 8 cfm pump without any problems, that would save me a couple hundred dollars. Well, actually it would save my Mom a couple hundred dollars.
spaceman spif is offline   Reply With Quote
Old 03-16-2011, 04:57 PM   #2
Owner
LateralConcepts's Avatar
You could probably save your mother hundreds of dollars on her electric bill by eliminating it all together. Just my 2 cents
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 03-16-2011, 05:03 PM   #3
When I read the first part of your reply, a gecko with an Australian accent popped into my head....
Old 03-16-2011, 05:12 PM   #4
Whoops...accidentally submitted my reply before finishing.
Can the tank work without an aerator? Doesn't the bacteria in the tank need the oxygen?
Old 03-16-2011, 05:21 PM   #5
Owner
No problem mate
Tell me more about the septic system. Do you know what size the tank is? When it was installed? What type of leaching system/drain field do you have? If you're unsure, your local health department may have records. Post a picture if you can. Most aeration systems are just gimmicks.
Lateral
(208) 818-8241
Old 03-16-2011, 05:31 PM   #6
All I know is the tank and pump and all were built 20 years ago. My Mom is currently digging through her records to see if she can find out any more.
Old 03-16-2011, 05:38 PM   #7
Owner
Do you have a local health department that regulates permits?
They may have the records you need. If not, they would definitely have the answers you need. i.e. Whether an alternative (aerated) system is even necessary based on soil conditions, etc.
Lateral
(208) 818-8241
Old 03-16-2011, 05:41 PM   #8
My thoughts exactly! I was caught out by this question. I've lived on 3 septic systems in my life and none of them have had an aerator.
The only reason I can think of for an aerator to be there is if your mom's soil is anaerobic. Meaning that there's not enough air penetration through the soil to the septic field to help break down the sewage.
VIPlumber is offline   Reply With Quote
Old 03-16-2011, 05:53 PM   #9
Owner
So is your mom having problems with the septic system, back-ups, or is it just that the aerator stopped working?
Here's a good guide:
http://www.epa.gov/owm/septic/pubs/h...guide_long.pdf
Lateral
(208) 818-8241
Old 03-17-2011, 11:40 AM   #10
The aerator stopped working.
Got some more info - county codes require an aerator, and the tank is 1500 gallons.
So my next question is this...can I use a smaller CFM aerator, but set the timer to run a little longer so the total amount of air pumped in is the same, it just takes a little longer? Or would a smaller CFM pump have trouble pushing air through the diffuser and I'm asking for trouble?
I'm also trying to find out who originally did the installation and get some info from them. If they're still around!
Hot Water Tank Flammable Vapor Sensor Lockout - A.O. Smith - Promax taviyo Plumbing 11 08-14-2013 04:51 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Leaky Toilet Tank Valve Tuckahoe Sparkplug Plumbing 4 07-10-2010 06:21 AM
Need help with smelly and black well water!! HABSFAN2006 Plumbing 20 04-27-2009 10:54 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
