Advise On Reusing Compression Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2011, 09:40 PM   #1
Seasoned DIYer
Rewards Points: 150
Advise on reusing compression fittings
I have compression fitting shut-off valves and the stub-out is not long enough to allow cut and re-make new compression fitting, so I will have to reuse the existing nut and the olive.
It's been mentioned it can be done. If using a new fitting, the rule I think is hand tighten, then wrench it half a turn.
What is the correct torquing procedure if you're replacing a valve and reusing the compression fitting?
HVAC_NW is offline   Reply With Quote
Old 02-09-2011, 08:07 AM   #2
I replace compression valves all the time, reusing the old nut and ferrule(I think you called it an olive,I am unfamiliar with that term). I get them pretty tight. Maybe a whole turn to a turn and a half past hand tight. and if it leaks a little, go a little tighter.
broox is offline   Reply With Quote
Old 02-10-2011, 08:43 PM   #3
Seasoned DIYer
Rewards Points: 150
Is it considered permissible? If it leaked and caused water damage and insurance found out would they pay?
Old 02-10-2011, 09:51 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 676
You should ask them. I don't handle insurance claims.
Now that I think about it- they don't pay for much of anything
Old 02-11-2011, 07:25 AM   #5
Hmmmm, as insurance coverage consultants go, I am an excellent repair plumber. Seriously, I do not know if insurance covers any DIY projects gone bad. Maybe people with experience can chime in. If you are really worried about the liability aspect, have a plumbing company repair it. It would be embarassing to tell your agent "the guy on the internet told me to do it like this, I can't believe it did not work!!"
Old 02-11-2011, 08:35 AM   #6
Rewards Points: 1,216
"Yeah, have a plumbing repair company fix it then they are responsible for it".
COLDIRON is offline   Reply With Quote
Potable compression fittings for pex-al-pex? mysterylectric Plumbing 2 02-07-2011 03:11 PM
compression fittings on copper pipes Gabriel24 Plumbing 17 10-21-2010 10:28 AM
Compression Fittings HollandAce Plumbing 3 08-14-2010 06:52 PM
Pex tubing & compression fittings Ultrarunner2017 Plumbing 2 02-11-2009 07:51 PM
Metric compression fittings ??? rutalkn Plumbing 3 11-27-2007 10:43 PM
