Advise Need: Husband Wants To Split Water Lines To Barn(s) - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-24-2010, 09:04 AM   #1
Advise need: Husband wants to split water lines to barn(s)
I married my husband about 2 years ago who is a dairy farmer. He sold his cows and now the dairy barn is empty, but has a separate barn on a hill with heifers. I am putting stuff in quotes here that I am not sure of but what the husband says..
There are two wells on the property: one is outside and has a "broken pump" that is reputed to have a direct line to the heifer shed. This well used to part of a house that "burnt down" and is troublesome to keep the pressure switch from "freezing".
The other well is in the basement of the farm house. I have lived there and the pressure switch sticks in freezing weather also. I told my husband to insulate it.
Now: This farm house well has a "pipe that goes to the cow barn"...(which the cow barn is now empty) and then goes to the heifer barn". There are two shut off valves inside the soon to be frozen cow barn on entrance and exit about 8 feet high up where the pipe comes in and out of the cow barn full of expensive milking pipe lines and water cut systems. Soon to be frozen and broken.
(In case readers are not aware of it, cows body heat keep a barn warm in winter). Oh, the hot water heater in the milk house needs to drained and those pipes also.
My husband wants to dig a huge trench and make a bypass and split the underground pipe outside so the other end will split off after the water exit to the heifer shed. He proposes to spit the pipe underground before it makes its entrance to the empty cow barn and then split and connect the other end of the bypass on the exit of the water pipe.
He then proposes to put "heat tapes) on the entry exit of the 8 foot section of pipe in -30 F Wisconsin Weathers.
I don't feel this will work because the 1) water pressure, 2) heat tapes break and won't keep it warm enough.
I feel that he should fix the broken well that goes to the heifer shed and look for some type of outdoor well solution, is there one? Then he can go ahead and turn off the water valve to the barn(s) from the farm house one and drain all the pipes and cow cups.
Please help me.
babalina is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
correct size pipe for water lines jce Plumbing 2 04-11-2010 08:23 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
