Advice On Venting Needed - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2013, 04:58 PM   #16
Newbie Bill
Rewards Points: 518
I think that OSB is dricore.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 01-31-2013, 05:04 PM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 350
Originally Posted by profcolli View Post
Here is another version - not sure if this is better than post #11 (I think I got the p-trap backwards there ), but it shows the tub and lav connection together. P-trap final location will depend on tub selection, but in this general area.
Horizontal (45 at each end in post #11) over to lav replaced with a 22.5 at each end - not sure if this slope is too much.
ePlumber - can you advise and also check the 2 questions in post #11?
Refresh my memory- correct me if I'm wrong
The 2" is to serve the tub.
The 2"x1.5" y is for a lav
Old 01-31-2013, 05:08 PM   #18
Originally Posted by pkrapp74 View Post
Are you putting the OSB directly on the concrete?
No, those are DriCore panels with a built-in membrane providing a thermal break and drainage channels underneath the OSB
Simpled Subfloor in Basement and Vents
profcolli is offline   Reply With Quote
Old 01-31-2013, 05:09 PM   #19
Yes, exactly so. The tub will be reduced from 2" to 1.5" at the upstream end of the wye.
Old 01-31-2013, 05:21 PM   #20
Plumber
Rewards Points: 350
I added some comments on the image-
Reason for upsizing the lav line is because it's actually helping to vent the tub. The extra volume insures proper tub venting with the lav draining(wet venting)
Reason for rolling wye flatter is to get the lav line below floor- keep it graded for drainage though
Old 01-31-2013, 05:30 PM   #21
Thanks! Unfortunately, can't move the wye further right than this without breaking up more of the floor - the 2" pipe also crosses over the main 4" sewer line just beyond that point. I could extend to the left of the wye (before reducing) a few more inches, if that has the same effect (see pics).
If I upsize the lav will that mean 2" all the way over to the ceiling vent? Or can I put a studor vent on the lav line (see post #11). There is a 2" vent within 5 feet downstream of the tub/lav wye.
I really appreciate all your help
Old 01-31-2013, 05:48 PM   #22
Plumber
Rewards Points: 350
Moving the wye would just give you more room to configure the tub trap- no biggie
I assume the tub will be against the end wall so the trap will be there as well- further then where you have it positioned.
The 2"vent line can be reduced to 1.5" after the lav tee in the wall- use a 2x1.5x1.5 tee- the top will be the vent, side branch will be the lav drain, 2" down to the wye.
I'm not a fan of studer vents so I'd say to run it over, but its your call. If you use one- It must be able to intake air so don't conceal it in a wall without using a louvered, removable grill in front of it.
I added another image to help clarify the wye. Disregard that it show a toilet and extra piping. I think you get it though. If you look at the vert, venting you'll see how the lav will look with the reducing tee. Point it what ever direction suits you
The Following User Says Thank You to TheEplumber For This Useful Post:
profcolli (01-31-2013)
Old 01-31-2013, 06:02 PM   #23
Thanks! Actually, the tub drain will be right around that point, it will be a clawfoot with a righthand drain, kneewall to hide all the plumbing, then lav on the other side. If it proves too difficult to sort out drain/overflow coming directly up from the floor, I have the option of putting the drain "through" the kneewall and then dropping into the trap in the access area that will be provided for all this plus the water pipes and faucets.
Good tip about the studor vent air grill - I would never have thought of that. I've only ever used them in "open to air" locations, but this would be behind a wall.
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 06:19 PM
Floating floor water damage - advice needed rumiat Flooring 3 05-28-2012 03:38 PM
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 08:02 PM
Subfloor Overhaul - Advice Needed kadams2345 Flooring 39 11-19-2011 02:02 AM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 08:03 PM
