Advice On Shower System - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-09-2009, 02:38 PM   #1
advice on shower system
hi again.
so i'm looking for a new shower system to use in my remodel. this will be shower only, no bath.
i'd like to have:
-on/off mixing valve
-3-function diverter valve (shower only, handshower only, both)
-wall mounted hand shower
-ceiling mounted shower head
total: $618.85
trim kit - 107.67
http://www.efaucets.com/detail.asp?Product_Id=T4111
valve - 134.13
http://www.efaucets.com/detail.asp?Product_Id=3320
shower head - 117.16
http://www.efaucets.com/detail.asp?Product_Id=6310
hand shower - 234.94
http://www.efaucets.com/detail.asp?Product_Id=3861
drop elbow - 24.95
http://cgi.ebay.com/Moen-A725BN-BRUS...3286.m20.l1116
does this seem about right for what it is? i feel like i might be missing a cheaper but still quality alternative but am not sure. the moen valve with integrated diverter seems like a good cost saver. it keeps me from buying a separate valve and trim kit.
i'm new to this so any and all advice is welcome and wanted.
thanks,
-djr
djrussell is offline   Reply With Quote
Old 07-11-2009, 03:51 PM   #2
bump. anybody?
Old 07-12-2009, 06:45 AM   #3
Man of many hats
wrangler's Avatar
Rewards Points: 354
That's cheaper than some of the Delta combos I have seen and looks like it will fit your needs. Plus less plumbing to achieve the same results than the Deltas I have used in the past. As long as it fits your budget, I'd say go for it.
Man of many hats
wrangler is offline   Reply With Quote
Old 07-13-2009, 10:39 AM   #4
thanks for the reassurance, wrangler. i kind of got sticker-shocked by the price of some of these things. i just wanted to do a gut check.
so i might go in a little different direction. swapping out the handshower for the integral body sprays will save nearly $200 which is a fair compromise to me. this is going in a townhouse also so i don't want to REALLY outclass the rest of it with a fancy spa system. also, this is a delta which is an upgrade from moen in my mind.
total - 432.48
trim - 272.00
http://www.efaucets.com/detail.asp?Product_Id=T18240-SS
valve - 70.98
http://www.efaucets.com/detail.asp?Product_Id=R18224-WS
shower head - 89.50
http://www.efaucets.com/detail.asp?Product_Id=RP52382SS
Kinetico Water Softeners -Reverse Osmosis Questions...Help - Advice wanted.. OverRunWithSons Plumbing 7 07-26-2009 12:14 AM
very low shower head flow rickard681 Plumbing 7 10-08-2008 06:43 AM
New House, new system, poor cooling Faulknertw HVAC 15 07-08-2008 10:06 PM
New System Advice jkspup22 HVAC 1 03-25-2008 08:48 AM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 08:07 PM
