Advice In Removing Plastic Drain Valve From Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2009, 03:52 PM   #1
Rewards Points: 682
advice in removing plastic drain valve from water heater
I am planning to remove a plastic drain valve from a water heater and replace it with a brass bib.
But last time I tried to remove a plastic drain valve it broke off, and I needed a handyman to help me remove the remains of the valve from the hot water heater threads.
Is there a relatively safe way to remove these plastic valves?
darsunt is offline   Reply With Quote
Old 06-15-2009, 05:30 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
I usually remove the handle and have at it with a pipe wrench. Pretty easy if done when the heater is new. And old heater -not so easy. If it breaks off, dig it out with a small chisel and a scratch awl. If You gnarl up the threads run a galvanized nipple in (galvanized because it is harder than brass and will cut threads in the tank brass.)
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
