Advice Is Not Always Correct! - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2011, 02:46 PM   #1
Rewards Points: 150
Advice is not always correct!
Ok Please be careful giving advice on here... Need to share a call from yesterday.
I got a call from a gentleman that explained that his toilet was clogged in the basement and he tried a plunger with no success. He then said he went on a DIY board and someone told him a snake from HD was easy to use and would save him a ton of money camopared to a Plumber on the weekend. So this guy who has a black and decker cordless screw driver as his only power tool went and rented a machine that I have seen take off a guys finger... because it will "save a ton of money and is easy to use" He said he went in about 2-3 feet and hit a stoppage turned it on and heard something "breaking" and now his snake is stuck.
I get up and head out to help him out. I get there and he is upset because he already paid for the machine and I said "If I can use the machine I will consider discounting it a little BUT LET'S SEE WHAT YOUR PROBLEM IS FIRST"
I go down stairs and look at the bathroom toilet and see a pipe coming straight out the back and going in the wall... I go in the room next to it and see "the grinder Pump" It is in quotes because I should say "what was left of the grinder pump" and of course... Tampons! So I think to myself and go back and look at the toilet and it is chipped and scratched.
So the job that would have cost him nothing to DIY or $135 for me to do is costing him about $1000 because someone took so bad advice...
Moral of the story
Be careful giving and receiving advice on here... If someone ask for more info try to give it... They may be having an idea that could save you money
And oh yeah--- Dont flush the Tamps into a grinder... the strings are a killer
Just in case my Pic does not post on what he had google this
Zoeller 202-1000 Qwik Jon 202 Ultima Grinder Tank
Docwhitley is offline   Reply With Quote
The Following User Says Thank You to Docwhitley For This Useful Post:
LateralConcepts (02-13-2011)
Old 02-13-2011, 03:13 PM   #2
Rewards Points: 262
I think this covers what you said pretty well:
"Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. DIYChatroom.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any home improvement task!"
Jim F is offline   Reply With Quote
Old 02-13-2011, 03:41 PM   #3
DIY staff
Rewards Points: 7,174
Well said,Doc----However, this site does do one heck of a job pointing people in the right direction--
It is common to see someone step in with a correction if misinformation is given.
An frankly,some people should not be allowed tools.
Good directions---fine written instructions all mean nothing if the person
receiving them lacks common sense and some small degree of mechanical ability.
---Have fun---Mike---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
AndyGump (02-13-2011), the_man (02-13-2011)
Old 02-13-2011, 09:02 PM   #4
Rewards Points: 338
some people aren't very mechanically inclined and tend to cause more damage than good trying to do things themselves. your example was an extreme case of things gone bad.
however, almost any DIY'er has at one point spent extra time and money fixing things they screwed up. the idea is that you learn and over time you save a lot of money. with things like plumbing and HVAC, there are so many simple DIY jobs that are no brainers and huge money savers.
NitroNate is offline   Reply With Quote
Old 02-13-2011, 09:49 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
you pays your money and takes your chances....edumacation ain't cheap
Tom Struble is offline   Reply With Quote
Old 02-13-2011, 11:41 PM   #6
yummy mummy's Avatar
Rewards Points: 1,016
Unfortunely, common sense is a novelty to some......
yummy mummy is offline   Reply With Quote
The Following 2 Users Say Thank You to yummy mummy For This Useful Post:
oh'mike (02-14-2011), Tom Struble (02-13-2011)
Old 02-13-2011, 11:53 PM   #7
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Always use common sense.
Old 02-14-2011, 08:43 AM   #8
DIY staff
Common sense----those are the Lincoln pennies? Can Canadian Maple leafs be substituted if the Home Depot is out of the Lincoln ones?
Old 02-14-2011, 09:08 AM   #9
the Musigician
DangerMouse's Avatar
Common sense..... is that like fanning the wiring harness hanging from the ceiling trying to get the smoke detector (that's actually beeping on a shelf in front of her) to stop beeping?
hmmmm...... common sense does seem to be necessary sometimes, huh?
DM
Old 02-14-2011, 10:12 PM   #10
And Still Learning
I think with the high level of unemployment people are attempting to repair things that they otherwise would never attempt.
Know It ALL is offline   Reply With Quote
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 10:30 AM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Install Vapor Barrier or Not Install...Advice Please.. HandyDave Building & Construction 4 02-17-2010 09:16 PM
New System Advice jkspup22 HVAC 1 03-25-2008 09:48 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
