Advice Needed On Difficult PVC Repair (photo) - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-12-2012, 10:16 PM   #1
Restoration professional
Rewards Points: 302
Advice needed on difficult PVC repair (photo)
How do I fix this difficult PVC crack? The elbows are flush, so there's no room for new solvent welding, and the final PVC fitting is proprietary and no longer manufactured. https://picasaweb.google.com/1155978...eat=directlink
halliwellc is offline   Reply With Quote
Old 09-12-2012, 10:19 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
what is this a Jacuzzi ? Take it back to the tee and reconstruct that complete section, if its return water you can use the pvc hose, glues just like pvc easy to work with.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 09-12-2012, 10:21 PM   #3
Rewards Points: 13,732
What's it mounted to?
Old 09-12-2012, 10:51 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I've had to do this before.... (not proud) but it worked.....
Those jacuzzi fittings should be 1" PVC, so if you can get your hands on some 1-1/4" fernco couplings, they will go over the fittings.
When I did it, it didn't leak. The tub was 40 years old, and in a rental... not worth replacing it to the owner, so there ya go.
Those things seem to have tons of stress on them to begin with for some reason. It sucks, but thats the way they did it back in the day. Now they use spa flex... we'll see how that holds up.
Journeyman Plumber
Old 09-12-2012, 11:31 PM   #5
Rewards Points: 302
Yep, 40 year old jacuzzi
It's the second model Jacuzzi tub ever made. I'd cut off and solvent weld the elbows, but the part that attaches to the tub has no nipple left. (There's a little tee where the air hose attaches and injects air.)
Old 09-13-2012, 09:14 AM   #6
Doing it myself
Alan's Avatar
http://images.drillspot.com/pimages/6922/692262_300.jpg
If you cut off the cracked side of the fitting, is there enough room on the upper end of the 90 for that^ ?
Journeyman Plumber
Hail damage roof and siding repair advice needed Ed G Building & Construction 3 06-24-2011 12:08 PM
Lots of advice needed - exterior painting. lazzlazz Painting 1 06-20-2011 07:56 PM
Roofing plywood advice needed jimd206 Roofing/Siding 2 04-24-2011 11:58 PM
Advice on deck repair gabchoud Carpentry 8 09-12-2009 01:13 PM
Need Sheetrock repair advice Giterdone Carpentry 6 02-03-2007 08:38 AM
