Advice Changing Bathroom Sink Supply Lines? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2014, 08:23 PM   #1
Advice changing bathroom sink supply lines?
I'm installing a new bathroom vanity w/ sink and fixtures; the current supply lines are hard plastic. Will I be able to easily replace them with flexible supply lines? Will the new, flexible supply lines attach to the shut-off valves without any modifications?
Also -- any recommendation on the type of flexible supply lines?
Attached are 2 pictures --
Thanks --
Advice changing bathroom sink supply lines?-supplylineattachedtoshutoff.jpg   Advice changing bathroom sink supply lines?-supplylinetofaucet.jpg
metazone is offline   Reply With Quote
Old 02-03-2014, 08:40 PM   #2
Owner
LateralConcepts's Avatar
Yes, won't be a problem. That compression nut comes off and the new stainless steel braided lines will screw right to the angle stop. Looks like you'll need 3/8" Comp. x 1/2" FIP. They come in different lengths, 6", 8", 10", 12... Be sure to get the proper length. A little long is better than having to stretch.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following 2 Users Say Thank You to LateralConcepts For This Useful Post:
metazone (02-04-2014), plummen (02-04-2014)
Old 02-04-2014, 07:50 AM   #3
Thanks, Brad --
Questions about leaking sink and supply lines longislander2 Plumbing 9 01-20-2014 11:56 AM
(Louisiana) What size pipe Sewer, Drain and fresh water supply lines cmb7684 Plumbing 0 04-23-2013 05:54 AM
Branching a bathroom supply line from 1/2" pipe ppeetteerr Plumbing 1 07-22-2012 02:46 PM
Turning off valves bathroom sink richard7994 Plumbing 3 11-28-2011 05:25 PM
add second bathroom sink - tap into original denemante Plumbing 1 03-22-2011 12:21 AM
