Old 06-20-2012, 12:57 PM   #16
MarginallyQualified
Advice on ABS fittings
Originally Posted by scarrylarry View Post
There is one more slight problem...
I read somewhere that (pipe) needs to be inserted at least a third of the way into the fitting.
Yes... 100% in so it bottoms out at the end is indeed more than 1/3.
I had to rip up more of the subfloor to see exactly what I had to work with and then it was just a matter of getting the parts and cut some pipe to length... The closet (toilet) flange is going to need a longer barrell on it...
Take a photo and post it.
TarheelTerp is online now   Reply With Quote
Old 06-20-2012, 02:18 PM   #17
Originally Posted by TarheelTerp View Post
Like couplings, tees, elbows, toilet flanges, etc ?
Yes... they make them.
As to "O.D." reference I'll assume you made a typo.
Pipe is measured on the INSIDE.
Pipe is measured in both I.D. And O.D. why? I.D. for fittings O.D. for making block outs here is a good example say your doing new construction and you want to have the DWV got through the stem wall and you put a Thin wall PVC 4" ID pipe there the OD of that pipe is 4" 1/16th were as ABS OD is 4" 1/8th You just pooched yourself when you tear that block out, out. Your 4 inch ABS will not fit thru the stem wall.
So you better know both. Also When Pipe fitting you need to know the OD to find the take offs for long radius 90's and such. So No pipe is not just measured in I.D.
Nailbags is online now   Reply With Quote
Old 06-20-2012, 10:37 PM   #18
Doing it myself
Alan's Avatar
I've never used an O.D. measurement on any drainage piping when referring to the piping in general.
Journeyman Plumber
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 12:02 PM
remove compound from brass fittings to unscrew fittings purpleheart Plumbing 3 05-08-2010 07:49 AM
DIY Advice Seeker - late 1970 seventies knockdown texture onegative Drywall & Plaster 1 04-22-2010 09:40 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
