-   -   Advice on ABS fittings (http://www.diychatroom.com/f7/advice-abs-fittings-146824/)
scarrylarry 06-12-2012 12:38 PM
Hi fellas.
I will start off with a simple question and see were I get from there.
Do they make ABS fittings that will go over 4 inch O.D. ABS pipe?
scarrylarry
TarheelTerp 06-12-2012 12:57 PM
Originally Posted by scarrylarry (Post 941784)
Do they make ABS fittings that will go over 4 inch ABS pipe?
Like couplings, tees, elbows, toilet flanges, etc ?
Yes... they make them.
As to "O.D." reference I'll assume you made a typo.
Pipe is measured on the INSIDE.
scarrylarry 06-12-2012 06:14 PM
I just knew I was not going to get through this one easily,well maybe easily for you guys is what I really mean.The toilet that was installed in our ensuite some 25 years ago was put in with a few errors this was long before we bought it.Now I'm doing a reno and you always find things once a floor is lifted up or a wall demolished.I need to replace the toilet flange and 90 degree elbow under it. So to do this I have to go back to where there's a straight piece of 4 inch O.D. pipe.The reason I'm giving this measurement is there may be a smaller diameter pipe inside it.I have only a small amount of pipe to work with and a small amount of room as I do not want to open the the downstairs ceiling up to get at the plumbing.Now I bet I have really opened a can of worms
Thanks Heeps
scarrylarry
joecaption 06-12-2012 06:19 PM
ABS is ABS, the sizes have not changed.
TheEplumber 06-12-2012 10:36 PM
199 Attachment(s)
Thanks Heeps
scarrylarry
Are you saying the pipe inside has a 4" OD? Is it plastic too?
scarrylarry 06-12-2012 11:06 PM
Joe,I realize ABS is ABS. One point I'm trying to make and make it without getting you guy's all tied up in knots is I do not know the I.D. (inside diameter) of the pipe as I have not cut it and I do not have a lot of space nor pipe to play with to make mistakes.
scarrylarry
scarrylarry 06-12-2012 11:11 PM
Eplumber
I'm trying to say that where there is a section of straight ABS pipe that I may be able to cut off and add to, has a 4inch O.D. So is there an ABS fitting that will go over a 4inch outside diameter with a tight fit and I would be able to glue it with ABS glue.I'm I making myself understood or is it clear as mud? I would take a picture but it would not show much,maybe a diagram would work.
TheEplumber 06-12-2012 11:22 PM
199 Attachment(s)
Originally Posted by scarrylarry (Post 942227)
Eplumber
I have never seen any ABS pipe with a OD of 4". 4" is roughly 4.5" OD
3" pipe is 3.5" OD.
Now, don't take offense but I suggest you double check your measurement. I believe you haven't cut the pipe so how did you determine 4" od without measuring across the cut piece?
TheEplumber 06-12-2012 11:45 PM
199 Attachment(s)
3" pipe is 3.5" OD.
A 3" coupling may have an approximate OD of 4" - never really measured one.
TarheelTerp 06-13-2012 07:17 AM
^^ This.
Also, go to the home center to measure some pipe and fittings there.
Maybe even buy a few to take home with you.
Alan 06-13-2012 09:00 AM
If it's 4" O.D. and looks kinda like ABS, it may be orangeburg.
:mad::furious: I've never seen 3" orangeburg around here so I don't even know if it really exists, but I know the 4" Orangeburg is a lot closer to 5" O.D. than it is to 4.5" O.D.
also ESPECIALLY if it's failing, it's going to be wider due to vertical compression.
scarrylarry 06-13-2012 12:55 PM
Are those scarry faces a way of saying your not quite happy with my posts? If so you have to remember the old line "if you don't ask you won't know". At 56 years I find that I am learning everyday.I know it must be frustrating when a homeowner posts a question that seems so obvious to a journeyman in any trade.
Thanks scarrylarry
scarrylarry 06-13-2012 12:58 PM
3" pipe is 3.5" OD.
No offense taken E plumber ! Your right, I have not yet cut the pipe.I'm going to double check the O.D. of the pipe,I'll use calipers.
scarrylarry
Alan 06-13-2012 07:51 PM
Thanks scarrylarry
Not at all, the mad faces were the fact that orangeburg still exists in the world.
scarrylarry 06-20-2012 09:32 AM
Yahoo !!
Thanks for all the help with the ABS toilet plumbing fellas it's finished,sort of !. I had to rip up more of the subfloor to see exactly what I had to work with and them it was just a matter of getting the parts and cut some pipe to length.
There is one more slight problem I will have once I lay the vinyl flooring down.The closet (toilet) flange is going to need a longer barrell on it because I think it needs to sit into the elbow beneath it a little further than it will.I read somewhere that it needs to be inserted at least a third of the way into the fitting.
scarrylarry
