Adventure Continues... Drain Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2013, 04:45 PM   #16
Rewards Points: 29
Yes the vent really oes out he window.... Like that when we moved in. When the sink was put in, no check valve was used and the bubbling was much worse.....
mkerns12 is offline   Reply With Quote
Old 01-08-2013, 04:49 PM   #17
Experienced
Jackofall1's Avatar
Define bubbling...is water squirting out the sink drain, or are you experiencing an annoying sound when the sump runs?
Old 01-08-2013, 04:50 PM   #18
Experienced
Jackofall1's Avatar
How far to the left is the sump?
Is there another check valve downstream of the point where the sink drain ties into the sump line?
What size piping does the sump line tie into ie the main drain?
Are you on a septic system of city sewer?
What color was Nepoleons white horse.....no that a different problem
Old 01-08-2013, 04:55 PM   #19
Rewards Points: 29
Correct on that! Then can I run the ink in where the sump currently ties into waste line?
Old 01-08-2013, 06:23 PM   #20
Plumber
TheEplumber's Avatar
Rewards Points: 664
I believe that was the suggestion in your original thread...
Old 01-08-2013, 08:42 PM   #21
Rewards Points: 29
The sump is around 6 ft to the left....no other check valve except right at the sump basin. City sewer here. Pretty sure it is 3 inch that it ties into.... Thanks for all he help!
setting a shower drain Jackets Plumbing 16 05-10-2012 08:48 PM
What is this thing?? Todd54 Plumbing 10 05-09-2012 04:18 AM
Avoiding a frozen paver drain BrandonC_1972 Plumbing 2 04-28-2012 09:11 AM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
