Old 01-06-2013, 07:43 PM   #1
Adventure continues... Drain help
After some local advise, I was told to drain my sink like the below photo. Sink drains fine but when the sump pump runs, which comes from the left in the PVC, the sink drain bubbles. Any advise on this would be great. As the photo shows, the drain runs from the sink to the sump drain line through the check valve. Thanks for the help!
mkerns12 is offline   Reply With Quote
Old 01-06-2013, 07:52 PM   #2
Roofmaster
Do you have a trap under the sink?
" A lot of men build things, and a lot of things fall down "
Old 01-06-2013, 07:59 PM   #3
Yep normal trap under there. The sink has a very short tailpipe.... Not sure if that would matter?
Old 01-06-2013, 08:31 PM   #4
Roofmaster
Do you have a standpipe to the left for your sump pump to dump into? Maybe an air break will stop the problem. Check to make sure your drain is clear also.
Old 01-06-2013, 08:59 PM   #5
I have a standpipe for the washer to drain into.... Drain is all clear! Keep the help coming!
Old 01-06-2013, 09:06 PM   #6
call me E
TheEplumber's Avatar
Put a vent on the sink line
Old 01-06-2013, 10:01 PM   #7
Experienced
Jackofall1's Avatar
You really shouldn't be tying the sink drain to the sump line to begin with as sink water is considered grey water and sump water is storm. Whether the sump is to a drainage ditch or city storm, you should be introducing grey water to either.
Old 01-07-2013, 06:45 AM   #8
The sump goes into the main drain for the house...
Old 01-07-2013, 10:28 AM   #9
Doing it myself
Alan's Avatar
I'm confused which one is which since you said the pump line comes from the left in pvc.
Journeyman Plumber
Old 01-07-2013, 10:44 AM   #10
That went from ugly to uglier!
Ishmael is offline   Reply With Quote
Old 01-07-2013, 05:02 PM   #11
Yea I didn't really understand the setup so thought some local advise would be better than going at it myself from what I found on here.... Guess I was wrong! The sump pump is to the left on the horizontal PVC and drains to the right into the main house drain.... I am assuming the PVC running vertical is up posed to be a vent... Runs out the basement window...
Old 01-08-2013, 05:19 PM   #12
Any more insight on this? Not sure how to fix and need some help!
Old 01-08-2013, 05:27 PM   #13
Roofmaster
The vent runs out the basement window????? Cmon man I just had a hip replacement, and your pulling my leg.
Old 01-08-2013, 05:39 PM   #14
Experienced
Jackofall1's Avatar
Well let me take a stab at it, when the sump runs the velocity of the liquid passing the "Y" in which the sink ties to, is creating a venturi effect causing the sink line check valve to lift from its seat, when the pressure equalizes the check closes creating a slight back pressure in the upstream section of the sink drain piping causing bubbles of air to rise through the sink trap.
Try running the sump without the check valve in the sink line, my guess that is whats causing the issue that is if there is no other check valve further down the line.
If there is another check valve then you may want to replace it, as it may be causing back pressure on the whole drain line piping you have there.
Mark
Old 01-08-2013, 05:43 PM   #15
I'm guessing it runs through the same window that dryer vent to the left runs through.
Disconnect the sump pump from your waste pipes and run it outside the house (not through the window though) to a point where it drains away from the house. In many areas it's illegal to run a sump pump into the waste system because it then needs to be treated like waste water. It can also overwhelm waste treatment systems during storms.
wrongdave is offline   Reply With Quote
setting a shower drain Jackets Plumbing 16 05-10-2012 09:48 PM
What is this thing?? Todd54 Plumbing 10 05-09-2012 05:18 AM
Avoiding a frozen paver drain BrandonC_1972 Plumbing 2 04-28-2012 10:11 AM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 07:52 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
