Old 02-25-2013, 10:54 AM   #1
Admiral washer cold water shutdown
on original fill and rinse fill cold water cuts off when well pump kicks on and water pressure rises above 43 psi. Hot water fill never affected. Help! please and Thanks
rpulley825 is offline   Reply With Quote
Old 02-25-2013, 10:58 AM   #2
Post the model #.
Sounds like it needs a new fill valve.
fine sand in cold water line, cold water stopping then turning hot and blasting sand cstrange Plumbing 2 12-02-2011 03:19 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
Leaking Water Heater (from Cold Inlet?) doesntmatter Plumbing 7 07-12-2010 10:30 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
