Adjusting Toilet Flange Height - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-04-2011, 07:53 AM   #1
Adjusting Toilet Flange height
I am replacing the whole bathroom floor, including a rotted subfloor. The new floor will be lower than the old floor. How do I remove the toilet flange to adjust for the new height. It is PVC and seems to be glued with PVC cement.. I would appreciate help on this task. Thank you,
burbanol is offline   Reply With Quote
Old 12-04-2011, 08:38 AM   #2
Rewards Points: 12,818
Why would the new floor be lower and not the same height?
If there's a crawl space or basement below just cut the pipe and pull out the whole flange and tail piece, when you go to put it back cut off some of the pie and use a hubless connecter to connect the two pieces.
It's easer to replace a subfloor anyway with the flange out of the way and the flange needs to be sitting on top of the subfloor.
Just make a note of the distance from each wall to the center of the pipe so you can use a hole saw to make a new hole once the subfloors in.
Old 12-04-2011, 08:59 AM   #3
Rewards Points: 2,512
Kind of like Joe said. I had to raise my flange after a ceramic floor install. I had easy access to 3" drain in basement. Cut 3", removed old flange. After tile installed I used a new flange, a long sweep elbow and a repair coupling.
I attached a few photos of my situation. Four of the five are taken in basement looking upwards to bath subfloor.
How about a few photos of your setup then maybe someone can give better advice.
Adjusting Toilet Flange height-111.jpg   Adjusting Toilet Flange height-plug.jpg   Adjusting Toilet Flange height-333.jpg   Adjusting Toilet Flange height-222.jpg   Adjusting Toilet Flange height-100_6557.jpg
hammerlane is offline   Reply With Quote
Old 12-15-2011, 02:09 AM   #4
Busy DIYer
picflight's Avatar
Rewards Points: 150
Why is your tank water supply coming up through the floor and not through the wall?
picflight is offline   Reply With Quote
Old 12-15-2011, 07:46 AM   #5
Because thats where the hole is and just so happens thats the same spot the 1/2 copper supply starts its upward turn.
Old 12-15-2011, 10:10 AM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 348
Nice. Why do people think water lines need to stub out walls anyways
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (12-15-2011)
Old 12-15-2011, 07:03 PM   #7
Busy DIYer
picflight's Avatar
Rewards Points: 150
Because they are cleaner installs!
Old 12-15-2011, 07:13 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Nawh!!!
Toe-may-toe/toe-mah-toe.
XXX
Old 12-15-2011, 08:01 PM   #9
Plumber
Rewards Points: 348
It may look cleaner to you but when you buy extra elbows and brackets for every fixture, it sure adds up
Old 12-15-2011, 08:16 PM   #10
Rewards Points: 582
why do you think they make straight and angle stops....
Old 12-16-2011, 05:25 AM   #11
Good point Ben
Old 12-16-2011, 06:44 PM   #12
Getting There
MecGen's Avatar
I have never seen a supply for a toilet come out from a wall, always on the floor, maybe its a regional thing? I am no plumber
Regards
MecGen is offline   Reply With Quote
Old 12-16-2011, 11:09 PM   #13
msaeger's Avatar
Rewards Points: 260
Mine come through the wall and I wish it was through the floor. I had a frikn drop ear in the wall start leaking and flood the walk in closet in the bathroom and part of the kitchen.
msaeger is offline   Reply With Quote
Old 12-17-2011, 12:07 AM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Drop ear on a toilet supply connection ???
XXX
Old 12-17-2011, 05:01 PM   #15
Rewards Points: 272
last time I used one was for the shower, but .....
fixrite is offline   Reply With Quote
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
Toilet flange height Joe F Plumbing 2 10-22-2010 08:49 PM
estimating flange height for rear outlet toilet JakAHearts Plumbing 6 07-04-2010 05:53 PM
