Adjusting Shower Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-23-2013, 01:45 PM   #1
Rewards Points: 87
adjusting shower vent
Can I change this shower vent to a 45 or 90 so that it will not interrupt my shower floor space vetically? Effectively move it into the floor / wall.
If not what are some alternative for moving it out of the way.
*Edit* The trap is not in its final location its just on there loose for now, it will be to the right and center in picture 4.
*Edit* I dont mind breaking the cement or raising my shower pan a few inches to get the proper angle I just want it mostly out of the floor.
hellonoko is offline   Reply With Quote
Old 04-23-2013, 02:26 PM   #2
Always learning...
fetzer85's Avatar
Rewards Points: 262
It doesn't look like it from the pics, but does that drain have a trap?
fetzer85 is offline   Reply With Quote
Old 04-23-2013, 02:59 PM   #3
Rewards Points: 87
@fetzer85 what do you mean by 'It doesn't look like it' I want to know if code allows it or not I can break the cement and wood and what not.
The trap is shown in every picture?
Old 04-23-2013, 03:03 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 346
You could move the vent downstream as much as 5 ft. from the trap(UPC) to hit the side wall of the shower.
Or you could roll the wye to a 45 angle and bring it up in the back wall. 45 is still considered vertical.
The Following User Says Thank You to TheEplumber For This Useful Post:
hellonoko (04-23-2013)
Old 04-23-2013, 03:11 PM   #5
Always learning...
fetzer85's Avatar
Rewards Points: 262
You answered my Q when you said you're not done w/ it yet, thanks.
Old 04-23-2013, 03:19 PM   #6
Rewards Points: 87
Just to make sure I am clear:
I could roll my wye [Red circle] to the left at 45 and then run my vent line [yellow lines] across at a 45 and up as I've crudely drawn below.
Old 04-23-2013, 03:31 PM   #7
Plumber
Rewards Points: 346
Yes sir. You want avoid laying it flat and using 90's- which is usually not allowed by code unless done above the flood rim of the fixture
Tags
drain , shower , vent
How to vent toilet, sink and shower on vent located on different wall? luvdairish Plumbing 11 05-12-2013 03:31 PM
Can a shower share a vent w/ the sink? CoconutPete Plumbing 2 04-04-2013 11:39 AM
Vent sizing pment Plumbing 5 04-19-2011 08:21 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
