Adjusting Hot Water Temp. - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2012, 10:11 AM   #1
Adjusting hot water temp.
This may not be in the right place, so please move it if necessary. I'm having an issue with my hot water upstairs not getting hot enough. Hot water heater in the basement, kitchen on first level (water gets very hot). Shower upstairs that is lukewarm. I have read that I can adjust a control on the shower, which I tried to do. However, it seems the previous owner also tried this and stripped the nut out that holds the handle in place to adjust the hot and cold. Has anyone come across this? If so, what was the fix. The shower head and control is Aqua Source. Thanks in advance.
Ken
kenasmith is offline   Reply With Quote
Old 10-15-2012, 10:22 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Sounds like your research is correct. More than likely there is an anti scald adjustment on the valve that needs to be tinkered with.
Don't know anything about that particular brand of valve (sounds like something they might sell at costco)
Might be in your best interest if you can afford it to get a price on swapping that valve with a name brand valve that you can easily work on and get repair parts for. Moen, Delta, American Standard.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
joecaption (10-15-2012)
Old 10-15-2012, 10:34 AM   #3
That is part of the issue. I can't remove the handle due to the nut being stripped out. I would like to replace it, however that entails removing the handle anyways. The research I have done, made it sound easy to adjust so replacing it would be a last resort. Is there another way to remove it, without damaging anything?
Old 10-15-2012, 12:27 PM   #4
Rewards Points: 254
use this to get the screw out http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
pwgsx is offline   Reply With Quote
Old 10-15-2012, 10:03 PM   #5
Doing it myself
Alan's Avatar
You're not going to be able to replace the trim (more than likely anyway) without putting a new valve body in the wall. Valve trims are specific to certain valve bodies.
Unless you can find a new trim kit for your valve, chances are you are going to replace the whole thing.
If the handle really won't come off (pictures would be helpful) you may be able to use a hacksaw to get it off of the valve STEM without damaging the stem itself. At that point you MAY be able to simply buy a handle rather than an entire trim kit, IF you can find it.
Notice there are a few what if's and mays there.
Journeyman Plumber
Can I turn off hot water to Washing Machine? okk Plumbing 12 08-10-2012 08:14 PM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 01:47 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
