Adjusting For Elbows In Gas Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-30-2007, 10:50 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,314
Adjusting for Elbows in Gas Line
Do you need to adjust for elbows for when determining the gas line size?
If so, what is the adjustment factor (ie 4 feet for 90 degree elbow, etc.)
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-30-2007, 01:46 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I've heard of adjusting for elbows on vent lines, such as for a clothes dryer, but I do not know of any reason to do so on a gas line. The pressure is maintained in gas pipes by the gas flow, no matter what the configuation.
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-30-2007, 02:30 PM   #3
(As I'm sure Clutchcargo knows ) In any pressurized system there are friction losses which increase with length of pipe, number of bends, speed of flow, and as diameter decreases.
I have no idea if those friction losses are enough to require that you account for them in gas plumbing, just saying that they definitely are a factor in pressurized systems, Mike. The pressure of gas flowing through a pipe will be less near the outlet than at the inlet.
NateHanson is offline   Reply With Quote
Old 10-01-2007, 02:05 PM   #4
I have gas!
Found it. The equivalent length for these pipe sizes are:
90 Elbows:
3/4" = 1'
1" = 2'
Tee (run):
3/4" = 0.5'
1" = 0.75'
Tee (Branch):
3/4" = 2.5'
1" = 3.5'
Gas Cock:
3/4" = 4'
1" = 5'
ac suction line placement? nimbenja HVAC 8 10-28-2009 06:43 AM
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
power line noise sciguy125 Electrical 5 12-02-2007 02:39 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 09:19 PM
