Adjust Toilet Position Without Breaking Anything? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-23-2011, 12:23 PM   #1
adjust toilet position without breaking anything?
Hi all!
Before breaking something, I would like some advice on this
Toilet was recently replaced but I realized after a few days that it is not perfectly aligned with the wall (it is leveled though). Can I just untight the commode bolts and align it better, or will I risk "disconnecting" the wax ring? Do wax rings allow for any adjustment several days after installation? Thank you for the precious advice!
sterv is offline   Reply With Quote
Old 11-23-2011, 12:30 PM   #2
Man, a new wax ring is like a couple of dollars. I would pull the commode and replace the wax ring instead of just trying to rotate it. It is possible you could move it without incident, but it is just as likely you would create a tiny leak.
broox is offline   Reply With Quote
Old 11-23-2011, 12:33 PM   #3
Lightfoot's Avatar
Rewards Points: 272
if it's just a small amount (say 1/4 inch or so side to side) you might be able to re-align the tank with the wall and not have to disturb the bowl or wax ring.
Lightfoot is offline   Reply With Quote
Old 11-23-2011, 12:34 PM   #4
Thank you! I will not take any risks then!
Old 11-23-2011, 12:36 PM   #5
It is actually the bowl that is not aligned by 1/2 inch :/
Old 11-23-2011, 12:38 PM   #6
Maybe you could move the wall
Old 11-23-2011, 01:04 PM   #7
Rewards Points: 190
A while ago I put in a new toilet and because I was afraid that tightening the bolts too much would crack the toilet, I didn't tighten them enough and the toilet shifted. I straightened the toilet out and tightened it some more. No leak. Try it. Worst case you have to change the ring if it leaks.
zircon is offline   Reply With Quote
Old 11-23-2011, 01:48 PM   #8
Rewards Points: 340
Take another look at Sterves comment -
It may be the tank that's off , not the bowl.
tribe_fan is offline   Reply With Quote
Old 11-23-2011, 01:58 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 684
Originally Posted by sterv View Post
Hi all!
If you had this professionally installed, call the professional back out
Old 11-23-2011, 09:18 PM   #10
Thank you all for the advices! Much appreciated!
how do i tell what size "rough in" my current toilet is? liverlipsyyz Plumbing 12 07-20-2012 01:39 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 07:41 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
