Adequate Insulation On Pipes? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-11-2011, 09:20 PM   #1
Adequate insulation on pipes?
I have started to put insulation on my pipes down in the basement. Before I got too far, I wanted to see if I was doing it properly.
The pipes in the picture are the hot and cold water pipes from my water heater. I used PE foam insulation, and put it all together with some silver tape.
Am I doing it right?
For comparison, here are the pipes before insulation:
thinksincode is offline   Reply With Quote
Old 12-11-2011, 09:37 PM   #2
Rewards Points: 12,824
That's fine but why are you doing it?
If the basement is above 32 deg. you do not need it.
They sell 90 deg. foam elbows so you do need all that foil tape.
Old 12-11-2011, 10:41 PM   #3
Well I read that it's good anyway on hot water pipes for energy savings (cold air can lower temp. in hot pipe as it travels to the faucet. On cold pipes it can help keep the pipe from getting condensation (or so I read in another thread on here).
Another reason is, even though I may not need it as much (though it can get pretty cold in Massachusetts in the winter) but just for the experience of doing it. I'm a first time homeowner trying to learn as I go.
Thanks for the tip about the elbow pieces. I'll keep an eye open.
Old 12-11-2011, 10:48 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
use black duct tape or electrical tape on the joints,will look much better
plummen is offline   Reply With Quote
Old 12-12-2011, 11:47 AM   #5
Rewards Points: 89
In my experience duct and electrical tape will fail after a few years. I'd stick with the foil tape. Who cares how it looks (as long as it's workmanlike), it's a basement....
Matt
gatorheel is offline   Reply With Quote
Old 12-12-2011, 12:03 PM   #6
plummen's Avatar
you have to use good electrical tape like 3m super33,not that 35 cents a roll jap wrap tape!
if you think that and the ul 181 tape on the water heater flue pipe look like good workmanship,might i suggest going to work for somebody as an apprentice till you learn a little more about quality work?
if youre going to put your name on something,i dont care if its a piece of pipe 20' underground make it look likeits the best work youve ever done or dont do it.
Old 12-12-2011, 12:20 PM   #7
Are you referring to the work I did in the picture?
I never said it was good workmanship, I was asking for feedback! A little constructive criticism might be better.
Old 12-12-2011, 12:24 PM   #8
plummen's Avatar
no i was referring to the other guys remarks about appearance not mattering on a job,didnt mean to throw you under the bus. sorry about that
Old 12-12-2011, 12:26 PM   #9
Oh, I'm sorry for misreading.
Is that bad workmanship, though, the foil tape on my water heater flue (bottom of the second picture)? Is there anything I can change to improve it? Thanks, and sorry again for misunderstanding
Old 12-12-2011, 12:28 PM   #10
plummen's Avatar
that flue pipe should have screws holding it together,if it has holes in the pipe it should be replaced not taped up
Old 12-12-2011, 12:29 PM   #11
Oh, boy.
Should I try taking off a piece of tape and see what's going on under there, or should I call someone instead?
Old 12-12-2011, 12:34 PM   #12
plummen's Avatar
id just peel the tape off and put 3 sheetmetal screws in each joint if they arent already there,if theres big gaps in the pipe joints go ahead and replace it.
its pretty simple to do with a set of snips and a drill
Old 12-12-2011, 12:35 PM   #13
Rewards Points: 89
I think we have different definitions of "workmanlike." I use it to mean functional , to code, and tidy. Personal aesthetic preference (silver vs. black) is not part of my definition. Personally, I think using electrical tape looks pretty hack. And I made no comment on the OP's photos-- my statement was made generally.
Matt
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 08:08 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
blow in insulation question Cool user name Remodeling 4 12-31-2010 12:24 AM
Adding attic insulation pomelo Building & Construction 3 10-22-2009 06:19 PM
Insulation around water pipes secutanudu Building & Construction 3 10-06-2009 09:32 AM
