Addition: Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-26-2011, 06:59 AM   #1
Addition: bathroom
I want to add a sink/toilet/shower at this location in the basement... there is a main coming from upstairs and directly under the toilet was this cap so I pulled it off and it was a drain pipe under it. can I add a toilet there? how could I instal a shower and where could I drain a sink? I can get water from the sink upstairs... Looking for some advice-be nice I'm a beginner! thanks!!
Photos
1. main drain line 2. hole that was capped off (you can see it at the bottom of the ladder leg in photo 1. ) 3. utility sink (just showing the layout) incase you have a better idea 4. above toilet drain,sink drain
Addition: bathroom-p1040612.jpg   Addition: bathroom-p1040611.jpg   Addition: bathroom-p1040613.jpg   Addition: bathroom-p1040615.jpg
latech1982 is offline   Reply With Quote
Old 04-26-2011, 07:21 AM   #2
Plumb or Die!
The hole in the floor is a cleanout. You can't add any plumbing (around here) till you're 1.5 meters from the base of the stack. That means jackhammering and/or building a subfloor to accomodate your horizontal drainage pipes for a bathroom or whatever. You will also have to find a way to vent your new stuff. But I find, anything is do-able!
plumber666 is offline   Reply With Quote
The Following User Says Thank You to plumber666 For This Useful Post:
DrHicks (04-26-2011)
Old 04-26-2011, 07:23 AM   #3
at the black cast iron pipe coming from the ground in the 1st photo on the opposite side of the photo there is a cleanout about 1' off the floor with the square looking bolt...why would I have 2 cleanouts so close to one another?
Old 04-26-2011, 08:10 AM   #4
Plumb or Die!
Is that hole trapped? As in, is it really a floor drain? The stacks both have cleanouts, might also be a seperate one for the horizontal building drain. Or even an abandoned stack.
Old 04-26-2011, 09:06 AM   #5
so if its an abandoned stack can I stick a toilet on it? or is that the worst thing you've ever heard?
Old 04-26-2011, 09:26 AM   #6
DIY staff
Rewards Points: 7,174
You are hoping to avoid jack hammering the floor?
Sorry---the only way to get the toilet plumbing to function properly will require opening the floor and adding a vent and the proper opening for the toilet---sink and shower/tub----
Mike
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
Piping Layout for New Bathroom structman Plumbing 2 02-23-2010 05:24 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Soundproofing a Bathroom jbitt Remodeling 8 01-29-2010 10:53 AM
to add an addition or not..... elmorem@gmail.com Building & Construction 2 02-17-2008 10:43 PM
