Adding A Washer/dryer To Existing Washer/dryer Setup - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2011, 11:39 PM   #1
Adding a washer/dryer to existing washer/dryer setup
I want to add another washer/dryer to an existing washer/dryer setup in our garage. How would I plumb this?
oper573 is offline   Reply With Quote
Old 01-30-2011, 09:48 AM   #2
Experienced
Jackofall1's Avatar
Drier ---- Gas or Electric? Don't combine vents
Washer ---Tee off the feed lines for the existing, you may have to increase the line size, if both machines start fill cycle at the same time you may not have enough flow capacity, resulting in longer fill times.
Adding to existing wall insulation in basement? Pjartsmile Remodeling 2 09-19-2010 01:06 PM
Adding radiant heat to existing slab Seabass HVAC 9 04-27-2007 04:10 PM
adding 3-way switch to existing circuit msahaydak Electrical 4 02-18-2007 12:43 AM
Adding Pergo to Existing floor jtyates533 Flooring 7 01-11-2007 01:55 PM
Adding onto an existing garage awayne Building & Construction 2 06-04-2006 09:16 PM
